246 Trailer Bearing/Spindle advice needed
This weekend I had a retaining washer break and the castle nut backed off causing issues on one of the four spindles of my boat trailer. Basically It got hot enough it was boiling the grease, steaming/smoking, and trashed the seal so it just started to sling grease out the back.
As a result I redid both sides of that axle...all new bearings, races, and seals and a really good clean job. Note the other axle was replaced due to major failure last summer so I just re-lubed that one via the E-Z Lube fittings.
Now that I got it all back together I towed it about 15 miles, and when I arrived I felt all four hubs. 3 of the 4 I could grab but the one that had an issue was already very hot to the point I could not hold my finger to it.
I I have to believe that it could only be the pre-load on the bearings being to tight??? Can't think of anything else with all new bearings, races, and cleaned very well.
Thoughts?
Thoughts?
Another thought is that you should never do a thermal check using the front of your fingers - always use the backside of your fingers or hand in case the temps are much higher than you think. You burn a finger or two and that hand essentially becomes useless - if you burn the back of a finger, it'll hurt but you can still use your hand!
I had a caliper piston freeze up wouldn't completely release. I found it when grease was sizzling out of the hub after a short trip home from the lake. Took the caliper apart because I couldn't get the brake to release completely. After finally getting the piston out I found the seal metal was severely rusted and/or corroded around the piston. I took the other side caliper apart to inspect it and it was starting to do the same thing. Long story short. I was going to rebuild the calipers but it was just about as cheap to buy new complete calipers with pads from e-trailer.com. Brake pads were worn on the caliper that was dragging. I think the complete calipers were $75 each. elarson I would check this out causing the overheating of hub and might not have anything to do with the bearings.
