Intermittent Engine alarm upon startup
davisesq
Member Posts: 6 ✭
I took the boat out for 1st time and ran it for about 30 mins, and this alarm started. Lube oil monitor was full, temp gauge was fine, oil pressure gauge was fine. I have checked the voltage from the alternator, and there's a slight variation across one of a specific battery, (always around 12.5-12.7 vdc running @ 2k rpm) the other battery was constantly around 14+ vdc.
Look here for a list of alarm codes for Merc:
http://rinkerboats.vanillaforums.com/discussion/1042/encountering-faults-check-this-out
The float runs up and down on an SS pin. As @frenchship said it can get hung-up.
***** However, I respectfully suggest that you BE VERY CAREFUL when making sure the float can travel freely on the SS pin as there is an "E" clip that holds it in place that comes off easily. If that happens you will have to replace the whole reservoir.
.....ask me how I know! LOL
@daviseq did the alarm noise stay on the entire time? Sometimes the oil pressure sender will send some alarms if the engine oil is a bit low then stop after the engine oil heats up and expands a bit. Do you have closed cooling? Low coolant can trigger an alarm. If the battery that was registering 12.5 volts moved up and down from that point it might trigger an alarm too. You might want to load test it with a meter to see if it's sucking current.
You have ruled-out your IAC? You have checked the grounds for temp and oil senders - when they go bad they go to ground!.
@davisesq, I'm not lazy but you'll find a ton of information on the forum search if you go to the search box at the top of this page and type in IAC.....those little buggers, while totally necessary, are certainly a source of aggravation.
Re-read your original post if you were getting a normal temp reading the temperature sender (and gauge) should be fine as when they go they often ground-out and you'll see that. Normal temperature for 30 minutes should rule-out a restricted sea water flow....okay I'm still thinking about this!
