Starter Help
NRath
Member Posts: 135 ✭✭
Spur of the moment decision Friday, after literally 6 weeks of rain, its sunny and warm, and facing Memorial Day! Let's peel back the winter covers, start up the Captiva, and hit the lake for dinner and our first sunset! I had hauled it for a fill up about 2 weeks ago, battery was off the Tender since then. Got the water connected and boom! 2 cranks and it's alive- first time since last fall. It ran like a top. I ran it for about 5 mins, varying rpm's. The stars are aligning, gear loaded into boat and we're off. Ramps not too busy, got her dropped in, hit the key, primed the FI, went to crank and nothing. A little diagnosing and it came to a crescent wrench hitting the starter, got a weak 2 cranks, then nothing. An hour of diagnosing, it's back on the trailer. 3-1/2 hrs later, the starter is out- that is seriously no fun!! Especially the consideration of breaking a bolt or the tab on the block of the 4.3. PB Blaster to the rescue.
There are a horde of starters on Amazon/ebay in the $80 range, Chinese knock-offs I imagine. With a Korean made V-P costing ~250, they are strong candidates. However, getting stuck on the water trumps the $170 difference pretty quick. I always put Toyota parts in my Toyotas; the Jeep, not so much... Being a rookie boater, I don't know which way to go. Factory or aftermarket is the guidance I'm looking for. Or, at least, what have been you seasoned boater's experiences...
Thanks in advance for any suggestions.
Sierra International 18-5913 Delco Permanent Magnet Gear Reduction 2-Bolt Starter https://www.amazon.com/dp/B0000AZ7CG/ref=cm_sw_r_cp_api_Ko3sxbKBT7JH8
That actually leads to another thing i've wondered- the quality of Sierra products in general as they offer just about everything. Stealership had Sierra oil filter in Stock, but I had him order the v-p (I wasn't in a hurry). Took them a month, lol.
Ras, I looked at repairing- the solenoid can be had for about $30. At first glance, a complete new starter was little more than double and seemed the better route at that amount of money. I've had great success with repairing several starters. New contacts in a solenoid, new brushes, and a commutator cleaning does wonders. There's usually a local motor shop to get the parts from. Racing R/C cars as a kid has paid off with a lot of motor experience. I've seen some boat starters upwards of a grand! Rebuilding those is the only way to go on my budget.
FWIW, it's the contacts in my solenoid that have died, but these solenoids dont appear to be serviceable, ala the marine rating. I'm going to cut it open on a bandsaw at work tomorrow just for a look-see.
