Left Turn Signal not Working
Hi Guys, looking for some help with my left signal in trailer. I put a bulb tester on the 4 pin flat(alligator on the male end) and turned on lights. Bulb lights when probe end contacts female lead next to male pin. Next I select right turn signal and bulb in tester pulses(top female pin) When I select left turn there is nothing. Checked 3 10 amp fuses in vehicle.All good. Swapped left and right trailer signal relays under hood of truck, no difference. Lastly with alligator clip on male pin in 4 way I scraped yellow wire BEFORE it entered the factory connector on the truck(Chrysler Aspen) touched to bare wire and nothing. I read about bad grounds but I still have running and right functions. After 4 hours I am putting it out there to you.Is it possible somewhere right at the fuse box under hood to see if wire is energized thus eliminating harness issue? arrrrgh.... Going to hang a door at my cottage so hopefully I will have a few tips when I get back.
Brian
Brian
Best Answer
Cableguy Greg Member Posts: 5,048 ✭✭✭✭✭
Some newer trucks have separate fuses for the tow harness vs the vehicle harness. My Ford truck is that way so if the trailer blows a fuse, the truck still has lights. I would check that first.2008 280 Express Cruiser, 6.2MPI, B3, Pittsburgh, PA "Blue Ayes"
