Fridge Repair
Wildboating
Member Posts: 957 ✭✭✭
The fridge down stairs seems to not get cold inside the box on 110 or 12v, with that said the freezer box in the top of the fridge is frozen. Any ideas where to start and how to get these things back to working like new?
03' Rinker 342 FV
03' Rinker 342 FV
Too high of a pressure and it will trip the compressor on a high pressure sensor. Too low, it either trips or freezes up the condensor. This is all related to pressure.
1 - Pull it out and really clean the coils, fan, etc... 10+ years of dust and dog hair build up can easily be the culprit. These things need ventilation.
2 - Make sure the fan is running once I have it out. It should kick on. If it doesnt run, the fan is the issue.
3 - Thaw it out overnight even though I just started it a few weeks ago. They need to start cold and I put a bunch of warm water in it when I turned it on this year and thats the wrong thing to do. He said to re start it with nothing or preferably a big bag of ice as these things need to start out cold. After its good and cold then you can put warm water and beer in there to cool down but not on initial start up.
Hopefully this solves it, if not the issue is likely something electrical. He said something like 90% of the time on these Tundra's the issue is not freon related.
BTW, I replaced my front panel, which was faded off white, with a stainless panel from Metaldepot dot com for $25 plus shipping. It is brushed stainless and makes it look new.
