Jinked myself, Generator failed
Well after bragging about how well my generator ran the **** the quit while running. It will not restart, cranks without any ignition. Can someone point me to a service manual or a where to start? I use this thing non stop when we are away from anchor.
I never leave my shore power plugged in when making a switch-over like that. I'm not sure I had to disconnect them but I always did fearing some sort of power surge. Is there a fuse in the generator that may have been blown if you have already checked all of the breakers in the panel and the two big main breakers?
Starting simple: the fuel valve is open, right?
Did you check for spark at the plugs? There is a fuel filter at the fuel pump too, I got rid of it and just use the inline one. If I remember right, 1/4"npt threaded barbed fitting. Check the pigtail connection for the fuel pump too, I had that go bad on mine. Hard spliced it now.
You can easily pull the anti-diesel valve out too, if it is gummed up and sticks closed it stops the fuel flow. It is on the carb, just one wire goes to it. It is a needle solenoid.
Double check that fuel filter at the fuel pump inlet too. I just rely on the little in-line raycor filter.
