Mercury NMEA 2000 Gateway
I have a 2014 246 captiva. I am interested in connecting my engine to my simrad using nmea 2000. I was told i would need the Mercury NMEA 2000 Gateway.
does any one have any experience where this gets connected to. i was told it would be a port on behind my dash.
Does it get connected to theSmartCraft port on the DTS controller. if so where is that?
Any help will be greatly apprecited.
At the helm, remove the panel that holds the gauges, and look for a black plastic junction box with six SmartCraft ports. (At least, that's what you'd have on a 2-engine boat; I'm not sure about a single.) The junction box is about 5 inches long, and it's probably screwed to the fiberglass. The unused ports will be plugged by plastic plugs. Remove any one of them, and plug in the gateway. Then connect the N2K cable to your N2K network using a T connector.
If there are no other N2K devices, I think you can just plug the N2K cable directly into your Simrad.
http://www.veradoclubparts.com/v/vspfiles/photos/878492K14-2.jpg
It should be somewhere within a few feet of the shifter.
power cable / fusion radio/ ** gateway** / Fusion remote/ simrad/ fusion remote.
Do you all think it will work in this position?
This is is the connector that I plugged into on the rear of my 350 mpi:
