fresh eyes- purring like an angry kitten...
212rowboat
Member Posts: 2,591 ✭✭✭✭✭
I've kept quiet about this until I figured it out- but the truth is I didn't figure it out...
My new engine had issues.. the valve train wasn't tuned at all- I got to do some old school adjusting, and swapping of a few components... I expected the engine to run much better after that. nope.. it trickled off and then flat out wouldn't start... checked everything I could think of.. I was a hair from running a hot lead straight to the coil, thinking something was wrong with the wiring.. it had a new cap, and wires (plugs too), so I couldn't wrap my brain around what was causing my issue..
it was SO simple... and something I never would have guessed in a thousand seasons... SO simple...
a flippin' plug wire was bad... ONE... the guy who came to help has forgot more than I've ever known, and it took him about five minutes to figure it out. ONE plug wire, which is something I didn't know, will ground against a ground, and because of damaged filament, and the dizzy with spray juice indiscriminately... I never knew that.. I always figured there would be just a dead cylinder... nope...
I swapped out ONE wire with a new set I purchased, and that engine is PURRING... well, it's blop blop blopping in a way a good engine should, but it lives- the valves are now properly lashed and tuned, and she is DIALED in... the throttle response is incredible.. I set the advance @ 12* as the builder rec'd, but left it loosish and have a gun aboard to do the fine tuning... after about an hour of straight running on muffs, and varying throttle between 800 and 1800, the rings let loose and the blow by is minimal... the carb required some fine tuning... It'll pull 18" of vacuum at idle, which confuses me quite frankly- I was only expecting about 14 or so.. the needle on the vacuum gauge looks like a textbook for a healthy engine... that is one helpful tool everyone should have.
I ran off the specs to this guy, and he thinks that this engine is likely every bit of 280- if not 300 ponies... We'll see how she does... it'll be splashed in the morning. I'm actually really excited... this engine sounds M E A N... I may have a 19p 14.125" ron hill pleasure five for grabs- I'm thinking this engine will blow that poor prop out, and I'll be needing at least a 22p wheel of some flavor.
I didn't need to 'see' the spark after I replaced that one wire... I could HEAR it while turning the key at the helm and this fella grounding it against the block...
