2011 310EC Cockpit Ice Maker Question
We recently traded our 280 for a new (to us) 310. It's great, but I'm having an issue with the cockpit ice maker.
Water is leaking out of the tray and freezing on the back wall and bottom of the ice maker. On the advice of several people, I inspected the tray assembly and discovered a crack in the plastic. Here's the problem: It looks like I need to remove the entire ice maker in order to unplug the tray, but I can't figure out how to get that bad boy out of there. I think I've removed every relevant screw, but she won't budge.
Does anybody with experience have some words of wisdom?
Thanks!
Thanks!
We had to pull the ice maker out of a friend's boat. We removed everything and it felt like it was glued in. We worked different corners until it finally came out. if it had been my boat I would have had a heart attack. Once it was out we could see that the hole had been cut too small and it had just been jammed in. We had to cut an1/8 inch off ALL the way around to get it back in - obviously that's the same as 1/4 inch off the top and bottom. I was not impressed that someone at the factory had done that.
before you use the kind of force that we did please check to make sure there are no screws anywhere. I wouldn't want you to rip a door off, especially now we know what they cost.
Is there anything (like a trash container) that you can remove to look around the fridge with a camera or mirror?
When I decide to do a COMPLETE fix, I think I'll just hire it out, and let a professional take care of it.
If this type of upgrade is something you want, and it's in the budget for you, I say go for it. I'd do it again. Flaky ice maker notwithstanding, I couldn't be more pleased. Our 280 was a fantastic boat. The 310 is, in my opinion, better in just about every measurable way.
and a bottle of kicker.remove the epoxy that is there it should not be hard to remove since adhesion will be poor. Use a 100 grit sandpaper and sand both side of the crack. Then clean the area to remove any oil or finger grease, if the crack is wide enough apply the ca in the crack if nott you could widen the crack a bit then use the kicker to spray the glue it will immediately seize the glue do not use to much kicker just a slight miss let that dry for a minute then wipe off the excess kicker,then apply more CA over the crack and some on the side where you sand again a slight miss of kicker let dry for more minutes then the extra glue can be sand right (100 grit then finer if you want)away to make flush with the rest lf you want to make it more strong cut a piece of an old cotton t-shirt just a bit larger of the repair apply glue to the area and apply the cotton piece over the glue you pressing it
a bit more kicker and that will do the trick.
P.S. WATCH not to glue your finger together, use a small piece of plastic to apply the glue like a small spatula and again watch your fingers
I did own a company that our speciality was plastic repair. Sold it to buy a boat
