Replace hatch lifts on 370 transom locker
LaRea
Member, Moderator Posts: 7,934 mod
The 370 has a nice transom storage locker supported by a pair of gas-shock hatch lifts, but the hatch on mine doesn't open far enough. I want to replace the hatch lifts with longer ones so the locker will be easier to use. Anybody ever done it?
To use the hatch, you really have to kneel down on the seat and crawl into the locker. If it opened just a little farther, it would be make a big difference.
The ideal solution is a torsion spring.
Do you have any suggestions for a torsion spring?
The linear actuator could work, a rotary actuator even better and smaller too.
http://altramotion.com/newsroom/2015/10/ap-electric-rotary-actuator-for-salt-spreader
Like the above. Done right you could raise that hatch close to vertical!
An electric actuator would be cool, because it would let me stop the door at any desired height. But I'll probably just do gas lifts for now (only $15 each at GLS).
But I have to wonder: is there a reason Rinker designed it to open only halfway? Is there some interference that I will discover after installing the new lifts?
I picked 36/21 inches because GLS has that size in stock. But I'll need to verify the geometry by disconnecting the actuators and measuring.
GLS has this:
http://greatlakesskipper.com/ranger-6200802-barnes-gssx-14011-040-stainless-steel-28-16-1-2-inch-40-lb-boat-hatch-spring-lift-gas-shock
The length is perfect, but it's a different brand from the original Attwood lifts, so I'm not sure whether it will fit on the existing 10-mm ball mounts.
I'm wondering if it's possible to reach the breaker from the other side (under the seat).
