Weaver Davits
I own a 2005 320. I have the Weaver Davit installed in the cut outs of the swim platform. My issue is that I have a Mercury 270 Airdeck Inflatable. I want to install the snap Davit pads with the yokes on the inflatable to use the system. The issue is that the place to glue the hard pads with the yokes is right on top of the rub rail of the inflatable. Has anyone attempted to remove the rub rail? I was wondering if I could remove the section of the rub rail where I need to glue the pads to the inflatable? Thank you for any advice you may have.
LG
another idea used for the stand offs... get the adjustable version. on the big boat trunk area you should have two hand rails. port is horizontal and starboard is vertical. I placed bimini end caps with eye holes on the ends to the rails. these hold the stand offs and dinghy. hence no drilling or other hardware place on the back of your boat. zoom in on the picture and you might see them on the hand rails. put bigger washers as back plates to help support the tension the dinghy might put on them. 2 years set up this way and all is great.
@ Serenity, I had a smaller dingy with inflateable bottom. I used the cut outs rinker provided on the platform. but I wanted somthing more stable and faster for three adults and crabbing. dont worry about the dinghy being on an angle when in water on davits. that is normal. the only down fall with these davits is the waves work the pin back and they release when the dinghy is floating. I use a small bungie to hold the pin from working its self back.
Thanks for sharing!
