galley sink slow draining
ericdata
Member Posts: 38 ✭
Hello Everyone,
My sink is backed up, and drains really slow. Anyone have any tips on how to fix this?
Thanks!
@Shaun, I bet that funnel piece was to limit backflow too, in case water was coming UP the drain. A big issue for sailboats since they heel over so far, hence why they have a valve on every thru hull.
I know on mine, if I get water coming up with the distance it would have to go, I have bigger issues. I suspected this issue on my bilge pump (backflowing) so I added in a pipe loop to the through hull (and changed the thru hull to a 90 degree type)
ive had mine get clogged by a mud daubers nest before
I took a water hose and a coat hanger and cleaned it out
2007 rinker 270
"Julie Ann"
