Stereo won't turn on, any ideas?
After removing the shrink wrap and installing the battery I tried to turn on the stereo to have some music while cleaning and it would not work.  I had the ignition key in the ACC position.  The stereo is a Kenwood that the previous owner installed a few years ago.  Before I start taking things apart is there anything obvious that I should try first?  The stereo is mounted in the TV compartment above the opening for the TV (2003 270 FV) next to the head.
Thanks,
MDboater
Best Answer
  • RansnanRansnan Member Posts: 81 ✭✭
    Turn the breaker on, just a guess
    Try turning the key the other way, but not starting engine.
    Are the batteries on(battery switch, starboard wall as you enter through the transom door, under hatch cover)?
    Fuse, ground, corroded hot wire, someone got into the programming and shut-off faders, etc?
    Are you in salt?  My head unit just ceased to work this year. I played around with the connections a bit and could not get it to turn on. I chalked it up to years of exposure to salty air. Now I have to replace it. Honestly we dont use it much though. We have a battery powered BT speaker that whales. And it saves my boat batteries while on the hook.
    it's my personal experience that unless you buy a slip system, and slide your headset out and store it in a dry, temperate place, they last about two seasons... I don't care how good a system you buy.. with all those tiny circuits and exposed points, in salt air and humid conditions- spray from time to time and the big thing- bouncing about... they just don't last.... which is why i refuse to buy a high end system... i learned that lesson at least three times...
  • rasburyrasbury Member Posts: 8,965 ✭✭✭✭✭
    When I had similar problem, I found that my remotes either the helm or the swim platform were bad- worked fine when I disconnected them. I don't have remotes any longer but I can deal with that....when you open them up, not much to them.
    Great idea but that wasn't it.  Thanks!
    Breakers all appear to be on.
    The batteries are on, charged, and I tried all three positions on the selector.
    I would slide the radio out and check for constant 12v, accessory 12v(when key is turned) and ground... At least that will start you off in the right direction and you won't be chasing a ghost.
    I think the stereo is water cooled...which is why it didn't work on land.  Not sure where the seacock is for it.
    :wink:
  • PoingyPoingy Member Posts: 2
    check for loose connection on rear of stereo, the heavy harness if not secure can pull out.
    Pull the plug on the back of the radio for the remotes and eliminate that, just sayin..
    Do you realize this is an old thread, MD sold his boat
    I'm the new owner and the radio is currently working fine lol!
