Proper Winch Size
 elarson5757
                    Member Posts: 232 ✭✭
elarson5757
                    I have a 246CC with a 5050lb dry weight so say with a full tank and gear it's easily 5500lbs.
The Trailmaster trailer it came on is a bunk style trailer and the winch it came with has always felt very under capable to me. The winch itself is rated only for 1800lbs, only about 1/3rd of the boat weight.
I've googled the heII out of this and called eTrailer to get their input. All signs online point to 1/3 of boat weight being ok for the winch ONLY if it's a roller trailer and not typically used on steep launches. Short of that they suggest 50% of boat weight with a roller trailer and 100% of boat weight with a bunk?? Doesn't seem right as that would mean a winch rated for 5500 lbs for me and even more for 27' cruisers???
thoughts?
thoughts?
Post edited by raybo3 on
I called Trailmasterthis afternoon...they told me the 1800lb should not be on the trailer with a 5500lb boat. They suggested 1/2 boat weight unless I regularly used launches that didn't allow me to get 3/4 or more of the bunk in the water.
