350 MAG MPI distributor
While swapping out a distributor cap Saturday (2nd time I have done it, 1st time was the marina) I found the cap loose again. Well turns out the threaded part on the distributor is plastic. And it broke. Just a be careful note for those changing the cap. I have to replace the whole distributor, lucky I am able to get one from Alswagg for a great price.
I read a report from a vendor regarding nylon embrittlement, and I'd be willing to bet that dizzy is a nylon part. As many of us have found, nylon and plastics get brittle over time. As we could guess, this is a result of giving up their moisture- literally. Fortunately, these effects can be undone as the part can be "rehydrated". The recommendation was to place it in a sealed, humid environment- not so easy for us. But, if a person had a day or so as we often do, hit it with a water mist from a spray bottle a couple times a day and it will rejuvenate the slightly elastic nature of the material. At $900 to replace the dizzy, I'd have no problem keeping it damp a day or two giving myself the best chance at not breaking that tab.
That's a gm 5.7 housing. 98 PICK UP. you can get one from the dealer empty. Or you can get a new on from napa. Our mercs . don't use the cam sensor.
