How to minimize corrosion on the bearing carrier assembly?
MDboater
Member Posts: 298 ✭✭✭
Behind the forward propeller on my Bravo 3 drive I noticed some corrosion on the exposed edge of the bearing carrier assembly. Is there a recommended paint or other coating that can be used to minimize corrosion in this location?
Thanks,
MDboater
Thanks,
MDboater
Best Answer
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
Read through this thread: https://rinkerboats.vanillaforums.com/discussion/4801/refinishing-bravo-3-help/p107' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV)
I have some pitting as well and it looks very similar to yours. However my drive is original from 2005 used in salt the last 5 years. I have been putting primocon on the past few seasons and it has really helped.
Thank you for your comments. I am suspicious of the mercathode and trying to figure out how to test it. It can be tested using a mercruiser tester. It would surprise me if there isn't another solution.
I am the new owner of this boat now and I found out the mercathode was cracked and not working properly. I am having it replaced and hopefully the corrosion stops or slows down. Just a reminder to check your mercathodes!!
@MDboater
