brass water pump replacement
I have the old brass water pump on my 2003 350 mag mpi. When changing the impeller, mechanic noticed some scoring and said the pump would need to be replaced soon. The alarm went off yesterday when out on the water indicating overheating situation. What is the recommended replacement pump. I seem to remember reading on here that there is a better option than the brass pump. I'm hoping when I get this fixed, it will solve my other current problem of engine going into guardian mode above 2800 rpms. New fuel water sep,, new inline fuel filter, new plugs, distributor cap, etc. I'm assuming if the pump isn't supplying enough water, that could be the problem. If not, one of the fuel pumps or fuel regulator perhaps?
