Worst Decision Ever = Black Boat
elarson5757
Member Posts: 232 ✭✭
Doesnt matter how much I polish (or have it polished), wax, seal, wash, or pray...4-6 weeks later in the sun and it's looking chalky...HATE black...
ok I'm done with my tantrum now.
It only my opinion
before:
after:
actually, the first one is starboard side I haven't started on yet... the second is port side I just finished (well, finished the lower half)....
the port was actually worse than the starboard. it has the sun exposure where the port is tucked up next to the RV.
I'm about 4.5 hours into this... here is my recipe:
simple green sprayed through one of those pressure washer foamer things (if you don't have one I HIGHLY rec them)... rinse..
magic eraser.... all down starboard side top and bottom.... rinse..
1000 grit wet sandpaper... rinse...
1200~1500 Meguairs Cutting Compound (12) @ around 2kRPMs with orbital polisher... rinse...
2000 grit wet sand paper.... rinse... (the nasty stuff REALLY came off in this step- I guess I knocked it loose with the first?)
Meguairs Polishing compound (2).... polished in at 4k RPMs with same orbital buffer... rinse...
dry by hand...
carnuaba wax.... three coats... buff @ 6kRPMs with fine foam pad between each... whallah!
rinse...
here is the step all y'all miss, that makes a HUGE difference (and is a trick the pro's use but rarely speak of) Rain-X... yup... wipe it on... you'll be amazed how stuff falls right off of the boat with that stuff on it..
