Cleaning up outdrive
elarson5757elarson5757 Member Posts: 232 ✭✭
So what takes the white residue off the top of the bravo III where it tends to run hotter and evaporate the water off it?
    Lime away or similar product followed by a thorough rinse with clean water.
    elarson do you have a drive shower? I do and do not have the white stuff. other boats I've without drive shower always had the white film, and hard to get off. Lime away or clr
  • Robs_232Robs_232 Member Posts: 212 ✭✭✭
    Use CLR or The Works toilet bowl cleaner. It works great. Make sure you rinse well once done with cleaner. I put a drive shower on drive and calcium deposits are gone.
  • elarson5757elarson5757 Member Posts: 232 ✭✭
    I don't but I've done a lot of reading tonight and I'm ordering one...is there a preferred brand for the bravo 3?
    Driveshowers.com has one, no drilling.
    You will be glad you did.
    Ditto on Driveshower. Easy install.
    Drive shower is in my near future as well
    Boat Name: Knot A Worry
    Ordered a drive shower last night!!
