corroded ground block
i have an 06' 250ec, i am getting noise in the stereo when i turn on the 12v fans on the starboard side only. i found the ground block in the bilge mounted on the transom and it is corroded pretty good. i sprayed with some pb blaster to pull the screws and start cleaning it up but they are brass and starting to strip. any idea on how to free up the brass screws so that i can clean the ground block? CLR? should i just cut the connectors off of the wires and buy a new ground block?
