How do people position themselves to work below deck?
MDboater
Member Posts: 298 ✭✭✭
This might be a silly question but I find that I can rarely get my body into the position that I need to be in to work on the engine or other systems below deck in my 270FV (single engine). Most things are too far away to reach when lying on the deck and there is little room on the sides of the engine to crouch down or get in a stable (semi-comfortable) position. Many times I wish that I could just sit or lay on the engine but I don't see how to do that without breaking something. How much weight would the exhaust manifold riser support? That seems like a place to sit but I am concerned with putting too much weight there. As much as I enjoy taking on boat maintenance projects it seems like I always regret them because I can't reach/see/get at the thing I need to work on. After working below deck last weekend my arms were so bruised from propping myself up in unnatural ways that it looked like I was in a fight....and lost.
And a question to people how have owned 270s and moved up to bigger boats. Is there more room to work on the bigger boats given the twin engines?
Toughest job I had to take on so far was replacing the bravo fresh water pump while on the water and that resulted in some bloody knuckles.
Tightening the clamps was a B****
I once got stuck behind the generator on my last boat, a 2001 Regal 3780. 5 minutes to change 3 spark plugs, 30 minutes to get in/out.
I have a lot of room to work on my engine in my lil 212, but in all honesty, it takes no more than half an hour to pull an engine out of that boat- so for serious work to be done either on the boat or on the engine, I'm thinking I'll yank it right out and have at it.
pretty much, the outdrive (six bolts?) in one piece, the engine harness, the power steering lines (quick connects), the throttle and shift linkage, the battery lines, and the four bolts to the engine mounts- drop a hook from the wench, put the engine level bar on the lift-eyes, and zip it north.... seriously- 30 minutes...
Mad far as positions to work. I just find the most painful spot not lay on and take Tylenol and beer afterwords
