Changing impeller on Kohler generator
2000 310FV. My kohler generator (no sound box) quit pumping water and obviously shut down. I'm told that it is likely in need of a new impeller. My issue is that the impeller is on the side of the generator with only 3 inches or so of clearance to the bulkhead. Not enough room to get a socket wrench in there to remove the plate. And once the plate is off, not enough room to get pliers in there to remove the old impeller. Any tips or tricks on how best to do this?
It is directly behind the impeller housing, actually no need to even take the impeller housing off. Two bolts, hex head, top and bottom...(I had to buy more tools)...If for some reason the coupler breaks before it comes off, I learned that the plate (with the hole in it leading to the coupler) comes off with just two bolts. I had to fish the pieces out with my fingers, using a pretty small circular hole. I didn't learn it comes off so easily till later.
