RF Ground Point
Does anyone know where I would find this behind the dash? What does it even look like? I am trying to install new MFD this weekend.
Right now I have a compromise pole mounted vertical dipole that I fasten to the bow rail when I wish to operate. Coax from the antenna is fed back to a connector I have on the helm panel, from there coax routes to the inside of the boat where the radio is located. So if I follow it all out, the RF ground can be considered to be at the radio since the antenna is fed from there. The power leads for the radio go to directly to the house battery. If there are any RF currents in the power leads, the RF level on the battery post would be off set from its ground reference at the radio.
Does any of that make any sense?
Thanks! I asked around a little, it seems most people just combine the "RF ground" with the DC ground and wire them in together, so that is what I ended up doing. My new MFD (Multi-Function Display) is a Raymarine E97 and it is great! Now I just need to get the new radar, new transducer and a heading sensor so I can overlay the radar onto the map. I am selling all the original stuff, Raymarine C70 and Pathfinder radar.
