fuel pressue regulator
High pressure fuel pump winning and getting hot on a 5.7 Volvo penta due to clogged screen in regulator. I cleaned once and it stopped for a short time. Found out that Regal is saying to take off the screen and replace with e-clip. I can't find where to buy one. Does anyone have any idea where to buy one.
Best Answer
BellevilleMXZ Member Posts: 732 ✭✭✭
The eclip is for higher than normal pressure as it restricts the return. Doesn't cause noise unless its really plugged, should still be done though. There is a screen in each pump inlet from what I have read, and you can take the unit apart and clean it(paint chips) also I have read. I'll do mine this winter, its working fine so far. Plugged fuel filter will also cause noise as its on the inlet side of the pump. Volvo has a high capacity filter, 644 is last 3 numbers of the part# I think
Probably getting clogged due to the paint coming off inside. This is a known issue.
Ooops, I was talking about Mercruisers, not VP.
http://forums.iboats.com/forum/engine-repair-and-maintenance/volvo-penta-i-o-inboard-gas-engines-outdrives
Good info there
