What size prop do i need--no one from Rinker will respond to me !?
I have a brand new Rinker 2015 170 OB with a 90 hp 4 stroke mercury. I let the dealer with a 15 pitch prop , which is so far off I cannot even get a baseline reading to speak to mercury. they said to contact Rinker and find out what the manufacturer of the boat recommends with that specific paring of boat and motor. This sounds reasonable since my dealer is not helping much. But i have emailed, called and even private-chatted on Facebook and no one will answer any of my questions. I am so disappointed and heart broken that I need this help and can't find a reliable source to advise me.
any suggestions? Is there some secret password to speak to Rinker? I am exhausted.
Post edited by Beebe on
Best Answer
Cableguy Greg Member Posts: 5,052 ✭✭✭✭✭
If they don't make it right, I would call Kim Slocum or @wheatst (Steve Wheatley) at Rinker. Explain to them how you are getting the run around from your Rinker dealer. It never hurts to let them know how their company is being represented by the dealer.
you found the right place to get prop help though!!! Though I claim no expertise, I have a decent grip on the subject, and combined with others here knowledge, you'll be squared away quickly...
what RPM range are you seeing?
what is the prop brand/model? (good to know for geometry; i.e. cupping, rake, transition of pitch from front to back)
aluminum or stainless?
number of blades?
I think 6k is the ceiling of where you wanna be... not more... if I'm not crazy, between 5500 and 6000 is prescribed... so... you're under propped...
even on outboards, 3 and 4 blades play by the same rules (unless you're talking pontoon- that's a whole other story)....
1 inch in pitch moves you 200rpm's or close thereabouts.. up, lower, down higher... aluminum spins faster than stainless by about 100rpms... an added blade will cost you 50rpms... cupping effectively acts like a higher pitched prop, by about 100rpm slower turn, but not until you're all the way up on plane and after the water has transitioned down the blade and is flipping off the trailing edge... an aggressive pitch transitions as much as three full pitches from the leading edge of the blade to the trailing edge, and forces the water to push off of different places on the face of the blade determined by load (expressed by RPMs) on the prop.. rake will generally manifest on the front to back attitude of the boat, and is caused by the difference in angle of the blades entry into to water ahead and the angle it flips it off behind...
a lot to absorb, huh?
how much does your boat weigh? in the 2k range?
small hub on a merc >115hp outboard... largest diameter is what, 12 3/4"?
I'd think, decided on weight and what an average user would expect, you'd need at least a 17p 12.75" fury, turbo, or mirage geometry'esqued four bladed wheel on that thing in stainless... if aluminum you can possibly venture up to 19p three blade... these would be un-vented props, or at least with the vent inserts installed which, in effect, makes them unvented...
your dealer ought to make this right... Rinker can likely make them see it that way...
And yes way way to long to plane off and I have to have trim in just one specific spot to do so.
At first I thought it was way too small for this boat but this new insight by researching it's ##s are telling me it's too much for my boat...not in size but relating to the rake. Driving me crazy.
thank you so much for all your input. If it doesn't work out I may be back on here crying!
He likes to be cryptic.
Wish me good luck !
Geez Al, here I am at 1:56 in the morning laughing at your post. The Admiral will have me certified.
MY guess.... Steve is drinking too many margaritas in his hot tub/spa resort in C.C. and his beam has increased too much?
