Weird behavior - can't shut off 1 engine, have to shut both off.
So this is a weird one.  I went to start the engines the other day.  Then got an alarm from VesselView saying the drive fluid was low.  No problem, I got a tube of lower end lube and added it to the bottle.  This was with the engines both running.  The alarm stopped.  Everything happy.  Then I tried to shut off one engine.  Turn off key, no effect.  Turn key back to on position, turn other key off.  No effect, both engines still running.  Turn both keys off, both engines stop.  I have since restarted and tried this to the same end.  When both engines are running, I have to turn off both keys to get them to stop but can not stop one or the either one at a time.
Thoughts?
    Remove them and look at the wiring
    maybe they share a ground wire or something is shorting them out
    Hmm that comes from pure experience I bet
    Al, do you mean the gauge or the thing (sensor or whatever) getting the signal?
    I leaning toward haunted.
    OK I looked on GLS and I think I know what you mean.  It could be the round black thing behind the gauges (sync sending unit) that I've never known the identity of.  Easy test will be to disconnect it and see what happens.
    Thanks Al
    Still keeping the holy water as an option though....
  • Dream_InnDream_Inn Member, Moderator Posts: 7,764 mod
    Please keep us updated as this is really interesting.
    I unhooked the ignition wires from the round thing that feeds the gauge.  No change in behavior.  I opened the ignition switch panel and checked the purple wires for a short.  The meter says they are almost a dead short.  Not sure how useful that test is but it seemed odd.  Still digging.  Different problem now, Stbd engine does not want to start (cranks, will catch for 2 seconds then die.  Thinking fuel pump).  When I had the ignition switch area out I noticed that some of the wires seemed strange.  The Acc breaker was carrying the power to one of the ignition switches and some other plugs didn't match between the port and stbd switch.  I only looked at that because I found that turning the port key made the port engine crank (and start), but turning just the stbd key acted like the batteries were dead....unless port was running.  It appears that over the years someone changed a connection or 2 on the switches.  I used the wire diagram to put them where they should be.
    Really thinking the boat is haunted.
    Or something got messed up when the new starter solenoids were installed.
    Could be fuel pump but it's good you got wires figured out.
    Wondering if that wiring has something to do with what I've been told that when stbd engine is running, if port engine key is not turned on, you will get an alarm beep every so often.  But not the other way around.  Maybe Al can shed some light on that?
    Part of owning pre owned boats
    my boats dash was not only ripped apart by someone that had zero mechanical skills but wiring was a
    Starts briefly then quits sounds like fuel pump.  I had the same problem, along with others, LOL
  • raybo3raybo3 Administrator Posts: 5,559 admin
    I thought the reason that happens is because the boat is prewired for VV option. I am pretty sure (but not positive....lol) that how it was explained to me.
    OK so I was in the engine space replacing a cap and rotor and thought it was time I tried un-plugging one of the smartcraft plugs going to the VV to see if it had an effect on the ignition switch issue.  And it did.
    So, now I have to dig into the dash and see what was done versus what was supposed to be done.  I have a feeling that a multi-ignition adapter was not put in.  I have to count junction boxes too.
    This could solve a couple issues.  The good news is that the adapter is under $30.
    Mine does the same thing because vesselview.  I was told after the fact by merc the engineer who gave me the parts list shorted me a junction box which will causes this.   Running both engines to one junction will not hurt anything just causes this inconvenience.  I have yet to fix mine either.
    Hmmmm, OK when I get a chance I'll open my dash and take a look.
    Just like I said........LOL
    Sorta.  My boat was not pre-wired for VV.  I had it added after the fact.
    A friend of mine bought a brand new (at the time) 342 and had the same "problem" he call the dealer and was told the boat was wired for VV and that it was not a problem............
    Hmmmmm  To me, "wired for VV" means the plugs are in the dash and just have to be put onto the display.  In my case, the cable from the engines and harness which plugs into the VV had to be added.  So not sure what the term "wired for VV" is supposed to mean.
    Mine is a 2002 when Smartcraft was new.  :)
    @raybo3 i am thinking that if i had a dealer tell me that they would be referred to as my "former" dealer.
    Guy's guys this is common and not just on Rinkers. Former dealer???? Really? he is the best in my area and the most busy. His service is excellent and his prices are more than reasonable. Very very knowledgeable. BTW when I said it was because of VV well guess what? It was because of VV........ Hmmmmm
    Sorry but i have a problem with switches not working the way they are supposed to.  IT screams electrical problem or at very best pending electrical problem.   IF this was me i wouldn't be comfortable till the engines worked independently...as they should.
    David obviously its not an electrical "problem" or these boats would not be wired this way. Every marine mechanic I know knows about this "problem" so it must not be a problem after all. Also if you know how it works how is it a problem. They must be wired like this for a reason or they wouldn't be like this....... Just say'n
    Here is my set up. Dual engine adapter output to the VV mobile device.
    BD is this a pre-wire job or was this an add on? Just wondering...
    That is all my handiwork.
    @Black_Diamond, if I may say so - extremely professional installation. Rarely happens in the real world but how  (imo) it should.
    @Michael T. Thanks!!
    Awesome job DB......... Better than manufacturer....
    I agree it's due to VV.  I suspect (have to verify) that it's because my installer didn't use 2 junction boxes and the multi-ignition adapter.  That likely happned because all the VV connection had to be added as the boat was not "wired for VV" from the factory.  This is totally self inflicted.  Not faulting anybody but my installer.
    When asking around before I wired up the VV, I found nobody knew boo about it. I had Wally at Mercury verify what I needed, worked perfect (remember the port engine CityID code needs to be changed too).
    Easy fix to add the second junction box, connection cable and the dual engine output harness.
    FWIW. I have a few extra termination caps if anyone needs some.
