Water between teak wood and swim platform
PO put teak wood(faux maybe) and at the edges it looks as if the caulk is worn away.  When I step on the teak water and air bubbles come out.  I am nervous about this have caused damage or causing damage.  Does not seem soft.  1) Do I just let it dry out and then caulk? 2) Seen numerous marine caulks you guys have mentioned, some say 4200.  Anyone know what is best?  I am in a covered slip which helps.  Thanks for the help.
Patrick
06 Rinker 270
