Bravo 3 no water flow
jhofmann
Member Posts: 430 ✭✭✭
Had the outdrive off for the winter installed today and am getting no water flow with muffs. No issues last season. Could not find the muffs I have been using, but found an old pair from an alpha drive I used to have. If the pump was bad, wouldn't some water go through?
If the pump is getting water but not pumping, check for excessive wear of the inside of the pump body.
Happy boating!!
