Can't get my 2002 34V up on plane???
mcox
Member Posts: 5 ✭
It has twin 350 Mercs with double Brave propellers engines run fine without load up to 5000 RPM and run fine at low speed with load, but won't wind up past 3000 RPM so can't get up on plane.. Bilge is empty.. Trim tabs are set correctly, propellers are not fouled or bent.... Cannot figure it out????
there are several conditions that will make the computer (assuming you're mpi) reduce power.. most are accompanied by a code (beep).. some aren't .. it seems the fuel systems on these things aren't monitored, or are monitored poorly... a bad MAP/MAF or IAC will usually set a code- but that would be on a single engine and the other would work fine..
how fresh is the fuel filter? regulator?
The fuel system is largely unmonitored for some reason... A simple o2 sensor would fix that.. but I digress.. anyway..
If you can hit 5k, however you're doing that, unloaded, then the engines sound to me like they are being starved for either air or fuel... It doesn't take near as much fuel to rev unloaded as it does to rev under load, so I'd guess its a fuel delivery issue.. its both, not just one engine, which more or less makes it a common issue most likely..
Check your tank vent for obstructions.. check the filter- two years is likely too long, especially if its ethanol perversed fuel... Check your regulator.. check your pump..
Maf: mass air flow.. map: manifold absolute pressure.. its either one one the other, engines don't use both.. its two different schools of thought on how to measure air and deliver fuel properly.. iac: idle air control.. each engine has one, it determines how much air to pass when the blades are closed on the throttle body and achieve 650rpm for idle..
Edited: intake air temperature (iat) and maf's are the ones that are differing schools of thought, not maf's and map's.. oops.
check the tank vent.. it may be obstructed.. it may allow enough flow to rev @ 5kRPM, but that doesn't mean it allows enough to flow at 3kRPM+ under load...
same principle with filter(s)... a single fill of bad fuel can cause this, no matter the age of the filters (which is frustrating if a new filter is destroyed, but it did it's job, right?)...
because it's both engines and not just one- I'd rule spark out for the time being (unless the sync function has some sort of limit function that is based off the 'weakest link' engine, but I doubt they were that smart in '02)...
again because it is both engines, I'd rule out air-in-air-out, as it's unlikely that both intakes and/or exhausts are obstructed...
that leaves fuel....
you have a common fuel tank, tank has a single vent, and fuel tank has a common pick up.. I'm pretty sure the water separator/filter is common... that is where the attention should likely be placed first.
