2456730
    edited July 2016
    Haven't been able to swap sensors yet, needed did socket.
    However, I just discovered the good motor at idle holds a steady 14 degree advance at idle.  The trouble motor however is jumping from 10 degrees to 14 very erratically.  Could this be related.
    get a can of ether and carefully spray around the intake manifold in very short bursts... avoid the air hat- try not to get any in the path of the intended intake...
    if you find a spot that when hit with the ether/starting fluid revs the engine higher, you've found your vacuum leak.
    that is what this sounds precisely like- a slight vacuum leak...
    you said the engine was new?  it may have an unmarried surface, which likes to happen at the corners of the intake manifold on SBC's, if care isn't taken while seating the intake on the heads.
    The problem was there before replacing the long block as well.  The long block had a knock coming from the bottom end which i was told to be a spun rod bearing.   I will check to see if i can find a vacuum leak.  Thanks
    @212rowboat
    edited July 2016
    I was able to record some new runs.  Notice on the starboard motor from 60% throttle to 99% there is very little change in rpm.  However the port motor in that same range will significantly increase rpm and you can FEEL the boat lurch forward when applying the extra throttle.  The port motor runs about 45% to keep the same rpm as wide open on the starboard motor.
    Starboard Motor>  https://youtu.be/rDX63u_aygs
    edited July 2016
    watch your MAP in both runs....
    the barometric is of value here because the MAP value is expressed in PSI- so, deduct the baro from the PSI to express vacuum.  You're pulling a fine vacuum on the second clip even when you're coming up on plane and loading the engine- at idle, the vacuum signal is about what would be expected with a marine profile cam.  You're actually pressurizing the manifold on the starboard clip at times (higher in the RPM range).
    the timing jumping indicates an unregulated air source, too.
    look around the throttle body carefully for unplugged fittings... swap IAC's between engines... do the ether thing... if that checks out, do a compression test and a leak down test.
    get a vacuum gauge and find a port to use it on both engines.... I'll come back and edit this post (again) with what to look for.... with the exception of a computer and sensor monitoring, there is no better tool to diagnose an engine.
    actually, just check out this webpage and use the flash...
    CHART OF VACUUM READINGS
    Engine Speed Reading Indication of Engine Condition
    Smooth and steady idle
    (800 to 1200 RPM)
    Between 17 to 21 inches Engine is in Good Condition, but perform next test to be sure.
    Open and close throttle quickly Jumps from 2 to about 25 inches Engine is in Good Condition.
    Smooth and steady idle Steady, but lower than normal reading Worn rings, but perform next test to be sure.
    Open and close throttle quickly Jumps from 0 to 22 inches Confirms worn rings.
    Steady idle Intermittent dropping back 3 or 5 divisions and returns to normal Sticky Valves. If injection of penetrating oil into intake manifold temporarily stops pointer from dropping back, it's certain the valves are sticking.
    Steady 3000 RPM Pointer fluctuates rapidly, faster engine speed causes more pointer swing Weak valve springs.
    Steady idle Fast fluctuation between 14 to 19 points Worn intake valve stem guides. Excessive pointer vibration at all speeds indicates a leaky head gasket.
    Steady idle Constant drop Burnt valve or insufficient tappet clearance holding valve partly open or a spark plug occasionally miss firing.
    Steady idle Steady 8 to 14 inches Incorrect valve timing. It must also be remembered that vacuum leaks and/or poor compression can result in a low vacuum reading.
    Steady idle Steady 14 to 16 inches Incorrect ignition timing.
    Steady idle Drifting from 14 to 16 inches Plug gaps too close or points not synchronized..
    Steady idle Drifting 5 to 19 inches Compression leak between cylinders.
    Steady idle Steady below 5 inches Leaky manifold or carburetor gasket, or stuck manifold heat control valve.
    Steady idle Floats slowly between 12 and 16 inches Carburetor out of adjustment.
    Blipping engine speed Quick drop to zero then return to normal reading Muffler is clear.
    Blipping engine speed Slow drop of pointer then slow return to normal reading Muffler is choked or blocked.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,862 mod
    Nice little chart there Drew!
    Wow, Thanks Drew - 212..    So, if the MAP is less than the Baro we are pressuring the manifold?  Did i understand that correctly?
    opposite... I think I may have misrepresented that above... your baro is your baseline- say, 14.7 @ sea level on a perfect day... if you're @ 12.7psi, you're pulling two psi of vacuum... if you're @ 16.7, you're pressurizing the manifold 2psi... I don't know the equation off my head that translates psi to bar or inches of merc...
    it's a lot easier (for our brains) to use inches or bars than it is to reconcile pressure in psi against barometric pressure in psi, but doing it the way the computer does reconciles against barometric which is pretty important.
    point is, with your engines, there is a difference... it may be a vacuum leak.. it may be load (due to gearing)... it may be a valve train out of adjustment... it may be non-seated rings (new engine, right?), it may be worn rings, but- it's something, though...
    does your valve train make ANY noise whatsoever?
    it should, but just a tiny percussion- nothing that can be heard from a few steps away...
    if a single valve rocker is too tight, it can be leaving the intake valve slightly open which can cause the pressurized manifold- hence, the rising ABOVE barometric pressure in the first clip.  (expressed in psi and on the MAP reading).... other than silly blow by (which usually happens in crank case and not intake manifold) that's pretty much the only way to get pressure in your intake manifold... equilibrium, yes, pressure? hard to do without there being valve train issues.
    so.... get 'yern redneck stethoscope in hand (piece of water hose, long screwdriver, piece of pipe- something to place your ear on one side and the other on an area- creating isolation)....
    fire the engine...
    now this is scientific, so stay with me here:  listen for the woofwoof.... as you move the end of your 'sound isolation' device across the valve covers, from one end to the other, and comparing sounds- listen for the one going woofwoof...
    my guess is this is your issue...
    a new engine, it may not have been dialed other than initial....
    to adjust.... this is a messy job... warm engine... remove valve cover (one side at a time).. get a towel...  lay towel over other rockers tight enough that it won't get grabbed by the actuating rockers, and get your ratchet and socket ready (that matches the rocker arms mount).
    move from intake to intake valve/rocker (use runner feeds on intake manifold to identify which is which)... you simply loosen the nut until you hear decided popping as the rocker makes a gap between it and the push rod.. tighten the bolt until it's just barely audible... then, turn it 1/8th more... JUST ONE EIGHTH... move to the next one... when they're done, go ahead and do the exhaust ones on that bank... button that side up and move to the other side and do the same thing.... as a finished product, you're going to want to hear just the faintest series of slight slaps from that valve train.  you want the lifters charged with oil, and you want them to just slightly depress as the engine runs- slightly, like, .05 or thereabouts... sound, and feel is just as good as any other method, and the one I just described- though messy- is the best.
    having the valve rockers too tight wears on cams, and RPM's charge up the lifters and they'll lift more than they will on a resting engine, meaning a valve may be ever so slightly open, disallowing full compression to take place...
    betcha betcha....
    oh- spray the engine room/bilge with simple green or purple power PRIOR to making this adjustment... it makes clean up a breeze..
    edited July 2016
    Post edited by Wildboating on
    break out your hose and use it like a stethoscope, and compare it to the strong engine.   you're definitely pressurizing that intake manifold, and that needs to be explained.  it can account for your timing bounce for certain, and it can account for the engine not developing power for certain.
    Drew,  In the first clip labeled Starboard Motor you are saying you see the MAP exceed the Barometric pressure of 14.36?  I am not seeing this ever happen.
    On it.  Heading to boat.  Thanks so much!!!
    you're right- it didn't break barometric... but it came dang close and hovered above 14 at times... the other engine didn't struggle near as much...  it's not using that air efficiently... let's hope it's a simple valve adjustment or a easily discovered vacuum leak... let's vote against bad compression..
    Using my mechanic scope, i hear NOTHING, nothing at all along the valve covers of the new motor.  I did notice a difference in the tick of the injectors however if that adds anything.
    it may be as Al is indicating, then... a fuel contribution/balance thing...
  • Robs_232Robs_232 Member Posts: 212 ✭✭✭
    I recently had an engine issue with my 2004 Yukon Xl with 5.3L making strange noise. I bought a mechanics stethoscope at O'Rielly's auto for $10. Well worth the money as it makes listening to engine noises, like valve train or injectors, much easier. In the past I used a hose in the ear. The stethoscope helped me narrow the noise down to valve train noise in number 1 and number 7 cylinders. Injector clicking was consistent.
    I ended up having 2 rollers on those lifters (Vortec engine) that were galled or burred and damaged camshaft. Ended up replacing engine with a reman. long block.
    Thanks Rob, fortunately it all sounds good. New motor but chasing low rpm issue that existed with former engine.
    Crossing fingers, just put new injectors in.  Fuel pressure primed to about 50psi then rest at 45psi.   Blipping throttle in neutral psi stays above 40.  Going to check under load.
    Good luck
    This is rather vexing. If the gear ratio was off, that engine should sound like it is lugging.
    Injectors are pretty reliable fellas. Unless plugged up or bad electrical connection. I'd think it would run bad, not just rpm limited?
    it ought not drop 5psi off idle without load- or drop 5psi at all so far as that goes... the pressure is a constant no matter the volume... it's why you get larger injectors in the first place, and when they consume and request more fuel than available at the relative timing sync.
    this kinda lands your issues directly on a fuel pump, a clogged filter, an obstruction, or an unvented source.... I'd lean toward pump seeing as how the pressure dropped while unloaded.  there is no excuse for that other than clogged filter or bad pump...
    Injectors didn't help
    At idle 16 in vacuum.
    1700 rpm blip drops to 10 then jumps to 23
    2700 rpm steady raises to 19in then pull off throttle jumps to 24 quickly.
    2000 rpm driving 11in vaccum
    getting on plane about 0 in vacuum
    3500 rpm cruising 0 in vacuum
    Good motor
    1700 rpm blip drops to 4in then jumps to 21
    2700 rpm steady in neutral  drops to 10in then raises to 20 then raises to 24 when dropping throttle
    2000 rpm driving  bouncing between 10 and 14 in.
    Getting on plane bouncing between 1-4in
    Cruising 3500 rpm bouncing between 3-8 psi
