Exhaust Shutter Inspection
PartsMan
Member Posts: 246 ✭✭✭
Last night I pulled the boot to inspect the shutter. It must be below the water line because water came pouring into the boat. I thought you could inspect the shutters while in the water.
if the flaps were in good repair, there should not have been a flood- a trickle beyond doubt, but no huge gushers.
a matter of fact, if weight or wake/tide could cause such, I'd still lean toward adding at least a two inch riser spacer on either side...
the comment about needing spacers derives from my own thoughts, which is very pro-safety margin... if the waterline is at or above the top of the Y pipes, and the top of the elbow where it slips on the riser isn't at least a good six to eight inches higher than that, and without healthy flappers- it seems to me that a good wake, wave, or tide could easily push water into a resting engine- and where it would lay there in wait for an unsuspecting captain to come along and turn the key- Crunch... hydro lock.
Problem: Once on plane for 5-10 mins I'm getting a water flow alarm sending the boat into guardian mode.
