Anchor chain/rode Windlass issues.
Very frustrating problem with my windlass and anchor chain, when pulling the chain back in it sort of piles up on top of itself in the locker then binds up the windlass. The only fix is to go below remove the mirror and the round port cover and then move the chain around in the locker so it doesn't block the opening (that is the second issue). The opening for my 5/16 chain seems way too small, has anyone made it larger? Also, just bought new chain and rode this year and the windlass is having a real hard time making the transition from rode to chain when pulling it up, it gets to the transition and then just sort of spins until someone "helps" the chain start making contact with the gypsy and it will eventually grab. The combination of these three problems makes pulling anchor a major PITA and certainly a two person job, since I only have controls for the windlass at the helm. Does someone make an aftermarket control that could be stored until needed then plugged into the windlass directly?
I also have the same problem with the rode and chain piling up and jamming my windlass.At one time Al suggest removing 10 feet of rode, I did that but the problem is still there.I am lucky since I do have foot control at the windlass,so l carry a wooden dowel so I can push the chain and rode downward, but still a pita. If you find a solution let me know.
tks
Paul
I forgot to mention...I did replace the spring and arm a few years ago but it still slips.
@Liberty44140 - how hard was it to service the spring? Mine needs it.
Shop around on the net for
Lewmar 3-Button Windlass Wireless Remote Kit
they range from $230 to $290. Pretty easy to put in.
