How To Replace IAC
rinker270nbrinker270nb Member Posts: 207 ✭✭✭
I have heard of carrying an extra IAC, I am going to do the same but where is it located?  I am guessing it's a socket to pull it and replace and then plug it in.  I have a '15 383 Stroker EFI.  Thanks for all of your help!
    Pretty easy to replace.....it's mounted on the side of your throttle body.
  • brandonmayberrybrandonmayberry Member Posts: 226 ✭✭
    Usually held in by two phillips screws if i remember right.
    Here's what one looks like....I think the ones on the GM motors are very similar.
  • qwikwhipqwikwhip Member Posts: 63 ✭✭
    It's very easy to replace. Remove your plastic engine cover then your flame arrester. It will be right behind your throttle body. Remove the two allen head screws, unplug it then remove and replace. Honestly shouldn't take more than 15 minutes.
    2005 Captiva 232 Liberty Edition, MX6.2/B3, Corsa
    Also, the original one will be painted black. The replacement may be silver or black. I've seen both.
    When I changed the iAc on my 2001 305's the bolts were torque heads (star shaped). There was a start/stop process in the instructions to help the engine learn the iAc. Instructions cAme with it
    How often do these need to be replaced?
    Patrick
    06 Rinker 270
    When your motor(s) stop running at idle.
