Ice maker compressor
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
got to the boat tonight and turned on the ice maker. Checked it an hour later expecting it to be cold and it was still warm and no ice. Seems that the compressor will not turn on, it's as if it has no power. The panel switch is on as is the small switch on the front of the unit under the grill. I checked and it is getting power from behind. Has anyone had one die? Compressor? Thermostat? Fan?
was toasted. I posted up the manual on here. Could be a relay, thermostat too b
