2005 Rinker 360 - AC not working on Shore Power; but works on generator power.
jameswilliamsusmc
Member Posts: 9 ✭
I reviewed a similar thread from July 2015 regarding a 2000 340 with the same problem. However, the wiring and schematics on a 360 differ enough from the 340. Getting power at the dock. AC and all other systems work fine on generator, so I suspect the issue lies between the port side AC outlet and the AC panel. Wondering if anyone has solved this problem with a detailed solution.
Exactly what happened to my friend's cruiser.
When I received my brand new EC 360 the Starboard side shorepower was flashing reverse polarity at the panel. I pulled the inlet and looked at the wiring connections ALL were loose. We tightened them up and all was good.
Then I thought I had better look at the Port side (which was working fine) but the white was somewhat loose on it too.
IMO always check the fuses first then the wiring contacts.
IMO it is a good idea to check the wiring contacts of the Shorepower every two years.
BTW Shorepower is a great product but their black rubber gaskets do deteriorate ( father time and UVA/UVB as culprits) then they can allow water to leak into the wiring, into the side hull coring and down along the walls and interior raceways into the cabin.
