Stinky Bilge
Does anyone know of a good product/method for de-odorizing the bilge? It smells bad. Not like some critter crawled in there & died bad, but pretty bad. I don't want to use any thing that might cause harm to the fiberglass, but it would have to be strong enough to eliminate the smell. Is chlorine bleach a no-no?
    bat32bat32 Member Posts: 161 ✭✭✭
    edited July 2013
    I wouldn't use chlorine in an enclosed area and around sparks. I bought hull cleaner from West Marine. You just dump a couple ounces in and it gets mixed around with the existing water while under way. Then the bilge pump just pumps it all out. Seems to have reduced the musty smell.
    http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=11151&partNumber=10108710&langId=-1&searchKeyword=CLEANER-BILGE+PURO+DFE+GA
    mvnmvn Member, Moderator Posts: 744 mod
    I had a situation this spring where water got into the bilge from the swim deck. There was black mildew everywhere. I used a mild bleach solution, wiped everything down then followed up with a healthy dose of Aerospace 303 to shine everything up. So far, no mildew or odour has returned. The bilge has been very dry, except for that speedo tube issue recently!
    Mark
    2019 MTX20 Extreme
    The trick is to keep the water out and the smell will go with it.  Last year I had the smelly bilge thing and found out i was getting rain water in the bilge.  I know where it is coming from (still hard to prevent), but i now just vacuum it out as needed.  Once in a while I'll give a squirt of enviro friendly dish soap after I clean it out.
    Funny how water is a boat's worst enemy.
    Mark
    2019 MTX20 Extreme
    I have no choice on getting water in the bilge.  The mooring cover is actually designed not to be water tight and it channels water into the bilge.  So I'm stuck just treating what I get and turning on the bilge manually right when I get to the boat to evacuate what the automatic switch didn't get ( which is usually a few gallons.
