A/C not cold...I have questions
my 2004 270fv has one a/c-heat unit and it seems like it's not getting cold . It wasn't very impressive earlier in the season but it's been extremely hot lately here in philly and I feel it isn't working to specs.
1: what should the temp be at the vent?
2:can it be charged?
3: if it needs a charge, can that be done while unit is in the boat?
4: are there any filters or serviceable parts I should look at first?
@jmichaels, you'll appreciate this. I ' m staying in an ocean front condo in Estero Beach Fla. right now. Very hot and humid (which I Like) ....about 2 hours ago had to defrost he condo HVAC by initiating the reversing valve LOL! Yes, that works great :-)
Do you have water flow coming out of your through hull on the startboard side of the boat, under the captain's seat?? If not you have either lost prime on the pump or the strainer is blocked. Both are easy to fix.
If you do have good water flow then I'd say either a system problem (you need to reset things to factor settings) or low coolant pressure.
Ps: I have kids so it may have been monkeyed with.
Others in my area have this problem every year, thinking there is something wrong with their AC unit. It happens in August/September. Luckily I was informed of this the first year I had my boat. Out of curiosity what is the temp of the water body your boat is floating in? There is a correlation between the water temp and how cold your unit is able to cool the cabin. Here in Florida, around August, the water is in the mid to upper 80's, sometimes it can hit 90 degrees! The A/C unit might not be able to get your cabin down to 68! The air outside is in the high 70's, low 80's, but the boat hull is sitting in 88 degree water, that heat is also radiating through the hull. The circulating water through the A/C unit is also 88 degrees, certain smaller A/C units may not be able to remove that amount of heat.
Last weekend, it took at least 3 hours for my unit to cool the entire cabin to 70. Just something to think about.
good luck
I moved sensor from coil face to outside of intake to prevent false reading (although the installation manual suggests mounting inside grate next to coil, where it was)
im guessing an incorrect ambient temp sensor, depending on temp, would either prevent the start of compressor or keep it running. The compressor cycles fine imo.
Im guesing at the end of the day i need to check cold air temp( i think it should be colder) and maybe have an hvac guy put his gauges on the unit and check refrigerant level....
