Adding an inverter
Hi I have a 2006 270 Fiesta Vee.Has anyone connected an inverter through the generator circuit.If so is the generator main on the power panel pre wired to the engine compartment or do you have to make a wire run from the panel to the engine compartment.
Mark B,
Thanks for the quick reply to clarify there is no generator installed on this boat . For the amount of ac power I need I want to permanent mount a 2k inverter on the bulkhead in the engine compartment and be able to control the inverter from the main power panel using the generator main breaker.The question I have is there a wire harness from the panel to the engine compartment that is not being used or do I need to run my own wiring from the panel back.
Mark B,
Post edited by JimW on
Sorry please clarify ... your generator is making 110V right? What do you want an inverter for? Do you want to go to 12V? Your generator should be going through your battery charger to resupply the batteries with 12V, so you can keep using your 12V accessories.
Why do you need an inverter on a generator? Just want to understand what you're trying to do before we give advice.
In a perfect world I'd like a generator but by adding an extra battery and inverter, I'd be happy running fridge, fans and tv's while taking days trips and allowing alternators to help charge while underway.
Welding cable and big honking connectors and mount the inverter anywhere in the boat except for the engine compartment
http://www.magnum-dimensions.com/product-inverter/2400w-12vdc-pure-sine-inverter-n-series
It only my opinion.
Paul
I did that exact same thing on an older boat that I had. The boat was prewired for a generator and I just tapped into that circuit with a 2000 watt inverter mounted on the bulkhead. I changed my house batts to 3 group 31's and it had plenty of power for coffee maker and microwave.
An inverter built for marine use will be ok in the engine compartment. TON's of boats out there have them, many are OEM options.
