Batteries... Again
So, some very interested conversations regarding preferred type of battery chemistry the riggers here in Florida, I spoke with, prefer. Have been by several really big MARINE outfits while driving the Admiral around. Here's what the trend seems to be: forget flooded deep cycle batteries as toyallu yezterdaus news.....too heavy, too weak, too slow to re-charge, too few re-charges, too low a voltage and too heavy. One rigger said they're special order now as we consider them crap. So I asked what chemistries and models do you guys like?Im.....I think I got it right: Gel OK with great number ofre-charge cycles but poor re charge times, too heavy and AHs too low as we're their CCA and MCA. Liked AGMs for supervisor AHs re charge speed and CCA and MCA . I fact they are now moving into TPPL AGMs for even more superiority in every way. Sort of what I said in an rarlier post.....would be coming. But.....even I was surprised to see the number of MARINE Lithium-Ion batteries going into new cruisers and fishing boats. I was told 5 x longer life, 5x faster charging, 66% less weight, higher voltages available and better CCAs/MCAs and the AHS
s is waaay superior!
Q1
If I were buying now I would be happy with a Series 31 AGM, better yet a TPPL Series 31 AGM or maybe even a new MARINE Lithium-Ion........new Mercruiser smart phone engine data links.... New battery technology...... For some boaters...the times they are a-
changing?
Well that's my latest report on new trends from Florida......stay tuned for more! MT
Q1
changing?
I was at another marina this morning and heard the same thing.....flooded for small bowriders and or guys with limited finfs. Maybe gel for cruisers but the techs recommended AGMs. For cruisers over 40' or guys who anchor out a lot or use inverters ......TPPLs.
Not looking for an argument, just passing along things I see/hear (like the Mercruiser Smart Craft app) that I think the guys here on this forum will like.
Don't post much anymore, just comment if I have dealt with the issue myself or think someone is about to step on a land mine.
Just friendly advice from an old geezer that anyone is welcome to ignore :-)
Gotta go, the Admiral wants to do some shopping! Fantastic weather here at Estero Beach 95 degrees with 87% humidity - MYkind of weather!!!!!.... Walk on the beach, swim in the pool and a sore neck from trying to look at every boat on the water, in guys' driveways and then there's the marinas...... BIG smile on that one!
one of my projects was R&D and now fielding of multi million dollar systems for the armed forces that require 12v service (dc exclusively; even shore power is inverted prior to touching the system)... a few thousand dollars isn't going to make or break it, but the systems faulting while they're needed will- with a certainty and in a heartbeat...
money ain't got nuthin' to do with it. performance has everything to do with it. I'd love to seem more in tune with technological advancement and up-sell by tossing around 'AGM' or 'Gel Cell', but it would be proven to cut sharply into performance, and that ain't gonna happen.
IF the flooded 6v true deep cycles are MAINTAINED properly, the AGM's are second for a 12v or 24v configuration. that is to say the plates or any portion of them are never dry, and the battery never drops below 50% capacity... now- AGM's can handle down to 30% before damage occurs, and if that is something expected, then maybe AGMs are worth another look. If weight is more important, AGM is the way to go.
After looking all over the internet, this one appears to be the absolute BEST bang for the buck. http://www.homedepot.com/p/Nautilus-31-Deep-Cycle-Marine-Battery-31MDC/205309650
They have a very comparable cca and Reserve time out of ALL of them that I have found so far in Group 31 size for half the price of a gel or AGM
Can you beat that ??
less reserve capacity and 70 bucks more each.. homedepot battery still wins..
you'd be even better to find some Trojan 6v in the same size (GC2).
@20a they're rated @ 230 hours.... you'd be running 4 of them in about the same footprint and weight as 2 group 31 batteries. the combined rating @12vdc with two sets of series batteries combined in one parallel bank is 460 hours, and so long as you keep the plates wet and never discharge below 50% will last you a long time.... unlike anything called 'group 31', these are true deep cycle/cell batteries and will work as good and as long as anything you can put in there.
these are intended for house batteries... not for cranking duties...
