Has anyone used Diablo Royal lights on there 270 fiesta Vee or similar? Which light? Pics?
jmichels
Member Posts: 311 ✭✭
I am looking at adding some underwater lights under my swim platform. I did some research and this company seems to have very well made stuff and very good light output. I contacted them and the suggested for my boat I used the Vega . Knowing how deep our transom plug do you think this will work?
http://boatpluglight.com/products/the-vega-off-shore-series-prd-8000-lumens
There are at least two other considerations. The light will be not only deep but behind the outdrive in our single engine applications. These light will draw about 11 Amps. Without a generator you will need to monitor how long you use them when on the hook.
This thread shows the AGPtek drain plug light (1800 lumens) at 4 inch depth. Remember that light absorption is logarithmic not linear so 4 times the lumens with not provide 4 times the penetration.
https://rinkerboats.vanillaforums.com/discussion/5615/ocean-led-underwater-light-installation-total-disappointment#latest
If your boat is on a trailer or lift? I might have another option for you. Let me know.
watts/volts
This family is looking forward to February as we head to St John. The plan is to rent a cat for a few days and explore the BVIs. Can't wait!
