Possible new owner of a 2001 Rinker 340 Fiesta Vee
spalmer114
Member Posts: 29 ✭✭
I have made an offer on a 2001 Rinker 340 Fiesta Vee and the survey is scheduled for this afternoon. I've already had a compression and leak down test done on both engines and everything looked good. I plan on being present during the survey and just wanted to get some input on any know issues of this particular year/model? This is my first boat, so I am trying to make sure I do not buy a "problem" boat. Any input would be greatly appreciated! Thank you!!
Very good news that the drives are Mercruiser. 277 hours is a very reasonable number IF the boat was reasonably maintained. Good luck!
P.S. Does it have a bolt on swim platform. If yes, look at where the SS struts meet the hull and where the bolts are. What shape is that area in?
Good luck!
I ended up servicing the motor and drive: Oil change, gear oil change, outdrive seals, water seperator, throttle cables, motor alignment check, bellows, water pump & starter.
To give you an idea, in Milwaukee, the price tag on that was around $4000.00.
1988 Rinker Fiesta Vee 250
1982 Ski Nautique 2001
Lots of boat builders wire the stereo to the accessory position of the key. I guess the theory is that you'll turn off the key when you leave, and the stereo won't drain the battery.
he will be broke with all the money he spent on diesel fuel by 1000 hours.
Wrong post - sorry!
