So what is the cost?
rasbury
Member Posts: 8,898 ✭✭✭✭✭
My boat is down for a coupler repair, 270. I'm thinking this would be a good time to change the bellows. I'm getting 100 different parts I should replace while down, the boat has only 200 hours. Not wanting to restart that conversation, I really am just asking, with the drive off, what would be a reasonable cost to add this to the other repair?
Best Answers
BellevilleMXZ
Member Posts: 732 ✭✭✭
If it was mine, I would do the inlet hose, as they are known issues, all bellows and boots, and the gimble bearing....why bearing? Why did coupler go so soon....probably way out out align.....that's **** the bearing......should not have to touch again for quite awhile after this.2005 Rinker 270 FV Volvo Penta 5.7Gi -
pault1216 Member Posts: 206 ✭✭✭
$1500 minimum for coupler and bellows service IMO with standard coupler. Upgrade add about $200-$300 more based on my experience 3 years ago. -Paul
rasbury
wow, I'm that for just the coupler, and was suggested on here that was a reasonable price. I hear you on the bearing as well....still, anyone have a recent repair for just bellows at this time? -
skennelly
Member Posts: 2,196 ✭✭✭✭
I had bellows done this past spring while I had the gimbal ring and bearing replaced. I can't find the exact labor charge but they told me it was cheaper because they already were taking the drive off for the other services. I want to say it worked out to around $500 for the bellows part...normally it would be close to $800.
2002 - 270FV Mag 350 B3 -
06Rinker270 Member Posts: 1,277 ✭✭✭
$440 @$110/HR for labor to remove drive, install u-joint bellows and gimbal bearing.
$100 for U joint bellows. $95 for Gimbal
Patrick
06 Rinker 270 -
Michael T
Member Posts: 7,241 ✭✭✭✭✭
@06Rinker270....that sounds decent. Parts same cost. We pay about the same here except our cdn $ works-out to $135/hr. So real close! (35% diff in the two dollars) -
Michael T
In our area the friggin' muskrats chew on the bellows so we have to look at them all the time and remember to trim down the drives LOL! -
summerx
Member Posts: 211 ✭✭✭
I would agree with Alswagg. replace ALL the bellows and the shift cable. parts cost is only a few hundred and shouldn't really be that much more in labor as they take that stuff apart to replace the coupler. even though there are only 200 hours, it is the years that will cause that stuff to wear out/dry rot.
I must amend my comment as that price was for coupler and drive service minus bellows parts. With bellows, bearing, and shift cable I think I have to add another $600 (Tennessee prices). -Paul
Handymans342
Member Posts: 10,375 ✭✭✭✭✭
Ras, break out the credit card, get everything fixed and we dont want to hear anymore till you are back in the water! LOL -
At the time my tech said all the other bellows looked new but I agree might as well do it all at same time. I will have to ask. He did a full drive service. Either way its now added to the list for this winter.
@rasbury I found this per Al's advice. Looks like $250. I wouldnt expect too much more labor than what I paid to do the rest.
http://www.michiganmotorz.com/bravo-genuine-mercruiser-transom-service-repair-p-1275.html?gclid=CJm4jsC4_c4CFddahgod9XMFxg
Patrick
06 Rinker 270 -
bigal6030 Member Posts: 157 ✭✭
I replaced my cone clutch last year and had the bellows and shift cable done at the same time. Saved some money, tell the shop to cut you a break since they are working on the drive anyway. $3000 for the cone clutch, bellows and shift cable.boat had 500 hours on the clock
Home port: Hammond Ind.
rasbury
Well, boat was fixed with no real conversation or suggestions for additional work. He left me a message it was done and to call. Sure wish I had time to splash but really busy... -
rasbury
The est was 1800, so far no mention of any issues. Not to bad I guess..another one of those times in glad I have one motor. Whish I knew why it failed with 200 hours. I just hope I'm done with this issue. -
Handymans342
They should tell you why it happened and what you have told us about this shop is very questionable -
Dream_Inn Member, Moderator Posts: 7,903 mod
Wow Ras! Really showing the age there with a great grandchild! Definite congrats due to you and your family! Cheers to good health! I want to see a picture of 4 generations on that boat!Dream 'Inn III -- 2008 400 Express
Wow Ras! You only have 12 years on me and my oldest is 16, so it better be a little while before I'm a grandparent
I can remember growing up always getting pictures with 3 generations above me. It was cool knowing my great grandfather. Couldn't imagine knowing another generation past that. Dream 'Inn III -- 2008 400 Express
