Go to West Marine...they have a couple of different sizes and fit the Rinker blade holder....ain't cheap though and ASSUME they will last a long time....
@Taz, brought boat home for some maintenance, took a couple pictures for ya, I have 2003 270 but they are probably the same, take a look. . Blade was 14 inches.
Cleaning them with some ww fluid from time to time (I used to use Rain X) keeps the rubber on the blade from stiffening and deteriorating. Just soak a rag and wipe each blade a few times.
Guys, do you have any movement in the joint where that screw is? Mine moves all over. May just need to tighten screw, hasn't been an issue but if I ever need the wiper I would like for it to work properly. Thanks. Shelby
2005 320 Twin 350 Mags MPI Bravo III Lake Cumberland, KY.
