outdrives
I have a 2003 34 ft Vista cruiser. My outdrives do not move. The oil reservoirs are full and you hear the pump running when you hit the switch on the controls but nothing moves. Unfortunately the out drives are not even and I cannot go above 10 miles an hour. Any ideas?
check with a test light that you are getting power to up and down pos from the switches.
there is a small drive key that fits into the motor and pump but from the sounds of it you have two trim pumps that are bad?
its real easy to trouble shoot. Start with wires to check for power.
remove motors to make sure the indeed rotate.
then onto the pump and make sure there is oil lol
now there might also be an issue with your limit switches but again two drives at the same time?
can you hit the trailer button?
are batteries in good standing and what is the voltage running to each motor
this is power related or somehow two pumps went. I did see a pump key break one time. So motor spins but not the pump
remove 4 screws and motor and then engage it to see if it spins.
Ps bad connection at battery or battery switch can lead to that also. Weak batteries and bad ground
other one was good and lifted like a champ
