Motor will not start
Bayrunner
                    Member Posts: 177 ✭✭✭
                    I had a leak from the block plug spraying water on the spark plugs causing the motor to turn off and not start. after replacing the block plug the motor turns over but will not start up and run.  Any help is well appreciated.
                Bayrunner -- FV312 - Simple Pleasure
