Shore power and battery
I have a fiesta 250 (2004) I plugged in my shore power but does not light up my panel switch does not stat on no lights also attempted to start boat only makes a rapid clicking sound starter does not engage.  Is they a overload switch or breaker I should set
thanks
  • Cableguy GregCableguy Greg Member Posts: 5,064 ✭✭✭✭✭
    Do you have shore power at 2 locations? Port and Startboard? If so, you have to make sure you are connected to the one that is selected. Sounds like your battery is dead.
  • jiminy1946jiminy1946 Member Posts: 5
    Charged battery started engine. Still have no shore piwer
    On the panel in the cabin, is there a switch stating "Generator, Port, Starboard?
    Sorry no generator.
    Is the shore power switch on at the dock? Most dock's have a breaker at the dock for the shore power outlet.
    Might want to post a pic of your power panel.
    Guys went back to boat removed and reconnect shore plug moved switch a lirrle and. The lights came on and it's on also Bastet charger
    i not going to question Why?
  • raybo3raybo3 Administrator Posts: 5,582 admin
    Sounds like a loose connection witch could cause a problem. Make sure connections are not getting hot.
  • Dan4754Dan4754 Member Posts: 80 ✭✭
    I apologize for high jacking this thread but it has been a while since I've been here and forgot how to search or start a new thread.
    Just came from visiting my 2005 fiesta 250 after a few months of neglect. Nothing electrical works...blower, lights,etc.
    When I turn on shore power switch I get a green light and the gauge goes up to about 80. If I turn on any other breaker switch, the shore power light goes off and the gauge drops to zero. An example is...with the shore power on I then turn on the fridge...shore power light goes out andd the fridge does not go on. And, of course if I turn off the shore power breaker everything is dead.
    Where do I start looking?
    Thanks
    Where the cord is attached to the boat
    get a multi meter and start testing. make sure you have 110 going through your cord for starters. then start pulling your shore power input plugs apart and making sure you have good connections. definitely have a connection problem with only showing 80volts on the panel. it should jump to 110 when you flip the breaker.
    The shore power cord is attached on the port side (?)
    Of course I will test the plug connections as you suggest Duane, but shouldn't the gauge read like "pass,fail"? I mean power or no power. I don' t see how a connection can reduce the voltage.
    Also, isn't it kinda mysterious that all of the power drops and the light goes off when I turn another breaker on?
     does your 04' have a shore power connection on the stern? if so switch inputs to see if it works through the stern. my 06' 250 has a stern input as well as the port side.  you can have a bad connection on your port side input plug that could cause lower voltage. you could have a bad main breaker causing low voltage. if you have 100 strands of copper making up the wire and 75 of them are broke, the voltage will drop.  when you pull your  shore power input, be sure to have some 3m 5200 caulk to seal it back when your done.
    Ok...its a 2005, though.
    I understand the voltage drop but what explains the light going out and the voltage going to zero when I turn on something else?
    Anything below 100v on the meter would be fail IMO.  Trick now is to find the problem (shore power source, cord, socket, panel) .
