What Moisture Meters will work without breaking the bank
I would like to buy a moisture meter but see them range from under $50 to over a few hundred dollars. Some below $100 state it can measure through materials as state;
- The water leak detector has separate settings for drywall, masonry, softwoods and hardwoods
- Moisture detection tool has a 3/4 inch (20mm) maximum sensing depth and +/-4% accuracy on wood
- Wood working tool is auto-calibrating and operates on 9V battery; 2-inch diagonal backlit LCD screen and a 3-color LED bar graph.
Bayrunner -- FV312 - Simple Pleasure
