Starting Issue
I noticed last season as well as this year that when starting my engine(350 mag) that with the first turn of the key ,the starter engages but quits after 1 second. I restart and get about 2 seconds of cranking before that too cuts out. Usually a third attempt the engine will fully crank until it fires then all is fine. Just curious what is starting to fail. Replaced battery in 2015 as well as starter solenoid(the one that sits on top of the engine that seems to fail often). It was random for a while but now becoming more common.
starter itself going bad
