comp cams xtreme marine
i am building a 377 stroker and found this comp xtreme marine cam that seems to be perfect with the power range being 1000-5000. does anyone here have experience with this cam? right now auto zone has 20% off ship to home which would bring their price to 663.99 with free shipping. the price is amazing so any thoughts on this cam before i make the purchase would be awesome. thanks in advance
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=201&sb=2
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=202&sb=2
https://m.summitracing.com/parts/nal-14097395
Short story: Two guys each bought brand new 26 ft scarabs, with the smallest big block they could get, both pulled engines out got rid of the whole engine, started form scratch building hot rod motors.
Both with different ideas on how to use different cams and pistons, Heads, and carbs, ect. One guy ended up putting 5 motors in his boat in two years. They would run great on the dino, but when they put them in the boat. They blew up. Those motors cost more than he payed for the boat. Then he sold it for half what he paid for the boat. Smart guy's lost about $100k. each. And he did not get to go boating much.
my HP hopes were in the 330-350 range. i am looking to get more low end torque than anything. i'm not looking to go 40mph in my 250 rinker, i just want to know that when i have 6 people on board with 50% fluids in the tanks and a cooler full of our favorite beverages, i can get on plain with more efficiency. i don't want to have to ask 3 of my 5 passengers to move forward so that i can plain out. i experienced that this year and i didn't like it. i'm perfectly fine cruising at 25-28mph but if i could move that to 30-32 i wouldn't complain. i just don't want it standing on it's stern trying to get on plain.
thanks AL. i always use trim tabs and drive all the way down. try to keep the cooler in the cabin and all safety gear stays under the seats in the cabin.
Always in fresh water, I'm surprised the exhaust manifolds need replaced.
I have always been a do it myself kind of person. i would be doing the assembly of the long block as well but he is only charging 275 bucks to assemble it, that to me is worth it for the 1 year warranty. for what I'm doing in the bilge compartment between cost of parts and time in cleaning, figure that I've saved a few grand in labor easy. not too mention the mark up on all the parts that I'm buying. i will certainly be painting it up and have it looking good. still debating on painting the bilge directly under the motor to clean it up and make it pop.
i bought the boat out of Tennessee, but you can see the shadow of FL in the gel coat so not so sure it's stayed in fresh water. one of the manifolds is newer and one is looking borderline. i figure with where I'm going with this build, and our plans to keep the boat for a while, I'm going to get new manifolds so i know what I've got. hopefully set it and forget it for a while!
spent 1900 at the machine shop with all new pistons, roller cam, lifters, crank, all necessary head work and assembled intake to oil pan, with a 12 month or 100 hour warranty. after i replace everything that i plan on replacing and doing the work myself, we will have a new engine, bilge pump, float switch, blower motors, cleaned the fresh water tank and holding tank, cleaned the bilge, in and out for less that 2500. got it all painted today and will start bolting on the brackets and externals tomorrow.
