Winterize water and waste tanks
Liberty44140Liberty44140 Posts: 4,414 ✭✭✭✭✭
of course I will run pink stuff through all of the lines and drain hot water tank separate. Question is on these tanks themselves as even after pump out and running the faucet until the water tank is low, there is still a couple of inches of liquid. Do you all dump pink stuff in to these tanks to keep those couple of in he's from freezing?
  • skennellyskennelly Posts: 2,196 ✭✭✭✭
    Yes I do.
  • randy56randy56 Posts: 4,085 ✭✭✭✭✭
    yes
  • DanD2DanD2 Posts: 848 ✭✭✭
    Absolutely...
  • Liberty44140Liberty44140 Posts: 4,414 ✭✭✭✭✭
    Thanks. Gallon a side? Half gal a side?
  • Cableguy GregCableguy Greg Posts: 5,077 ✭✭✭✭✭
    I would run at least a gallon a side. For the waste, pump the gallon thru the toilet, which winterizes the waste lines as well.
  • Dream_InnDream_Inn Posts: 7,937 mod
    I agree with Greg on the waste. Start from either the seacock or fresh water (depends on which your head draws from) and then pump it thru the entire system into your waste tank.  Obviously pump it out first.
    As far as water, I run mine as dry as a I can, then use an air compressor to blow out all the lines from the city water connection.  Then I remove the fitting on tank that goes to the pump and put that in a gallon of pink stuff and run thru.  I do not put any pink into my fresh water tank.  I then put a towel or two under my tank, lifting it up enough that there is no water near the connection end.  This helps a lot in the spring when it comes to cleaning it all out.  If you can't pump most of the water out and raise one end so it's not near the fitting, then you probably should put pink into the tank.
    Thanks! Agree to run. Gallon or so from the waste through hull through the toilet and right on in to the waste tank! For water I have a city connection that I was going to blow through but I have a Y valve before my freshwater pump that has a hose with no end. I'm supposed to open the Y so that I can suck antifreeze from that hose through the whole fw system. I may blow it all out first but this will make it easy to run pink. It is the tank and line to the Y that I was thinking about. Will pour a gal in the tank. Thanks!
  • onislandtimeonislandtime Posts: 309 ✭✭✭
    edited October 2016
    Check this youtube on winterization. This is how its done. Fitz's Fixes is pretty good at it. Saves tons of money doing it yourself!!!
    https://www.youtube.com/watch?v=N-pKC9JzuOw
    Thanks for the video! that is in line with my plan but it was great to see someone actually do it on the same boat. Great video! I hope that he usually looks at the air conditioner, generator, and engine exhaust thru hulls to actually see pink coming out, I certainly will! thanks again
    Well.... was thinking of doing a winterization video this year but after seeing this, there really is no need. I do mine slightly different but the video is good and gives everyone a good idea of what to do.
  • seguirseguir Posts: 170 ✭✭✭
    Question....After you run the pink through the engines....should you not then open the drain plugs and let the pink drain out of the engines?
    Al is going to disagree with you Handy.  But, I don't drain mine out either.  I pump out my water first so I know I am only putting in pink stuff.
  • raybo3raybo3 Posts: 5,614 admin
    Correct me if I am wrong by keeping the anti-freeze in the engines doesn't that help keeping the rust and corrosion down?
    edited October 2016
    Hmmmm.....I always empty mine. Maybe I should keep the pink crap in!!!
    keep it in.
    the pink stuff.
  • BellevilleMXZBellevilleMXZ Posts: 732 ✭✭✭
    lol
  • craigswardmtbcraigswardmtb Posts: 1,015 ✭✭✭
    That's what I have always been told. The pink prevents corrosion.
    Make sure you drain the heAt exchangers good. Water tends to get trapped in there.
    I hate we are talking about this. Another month until I pull my boat.
    I was right again LOL
    Oh Good God again............LOL
  • zaverin1zaverin1 Posts: 1,672 ✭✭✭
    I all reality not all pinks have protection from corrosion aka rust
    most basic pinks are actually just for water systems and not engines. I used pink in engines for years and never had issues. Some marine store pinks will say there is a some sort of an additive against corrosion. Wallmart and so on will have basic.
    now I did try the green and the blue pop which does state it's for engines and has all the protection from corrosion in the world. End result is the same lol
    video is spot on besides the engines. It's a good idea to drain. On boats with separate drains it's also good time to clear out some sand and dirt by flushing.
    i would always flush
    then bring engines up to temp for thermo to open and then winteriZe.
    most engines need 4 gal or so to cycle thru. Plus bravo vs alpha water pumps behave different.
    alphas are real pita to prime and high risk for burning up if not careful.
    here is what I do now
    Water system is identical to the video
    flush engines
    fog
    and drain.
    Thats it
    check lower drive for water intrusion by a small sample from the drain.
  • SeaHareSeaHare Posts: 194 ✭✭✭
    I just drain the engines and leave em empty... Not to worried about pink stuff keeping the rust away... my engines sit with lake water in the blocks all summer long...theres no rust inhibitors in the lake water last i checked
    01 FV 310, 5.7s carbed, B3s
  • diggin2day1diggin2day1 Posts: 1,331 ✭✭✭✭
    I never pull hoses off to winterize the AC... I just backfeed antifreeze into the thru-hull AC outlet until it pours out from underneath.
    I basically blow air through it from the through hull outlet. Been doing it that way on 3 separate boats since 2005.
